Saltar al contenido principal
ULCO ntegrus PSV ventilator Battery Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
    • Before disassembly, make sure the front wheel breaks are on.
    • Make sure ALL gas supplies are disconnected and the system has been purged, and make sure all electrical supplies have been disconnected.
  1. ULCO ntegrus PSV ventilator Battery Replacement: paso 4, imagen 1 de 1
    • With one hand on the ventilator removal handle and one holding the lower half of the ventilator, pull up firmly on the handle so that the mounting slides up the slots in the frame.
  2. ULCO ntegrus PSV ventilator Battery Replacement: paso 5, imagen 1 de 1
    • Pull the ventilator housing towards you so that the mounting tabs come out of the frame slots rest the ventilator housing on the plastic skirt at the rear of the workstation as shown in the photo.
  3. ULCO ntegrus PSV ventilator Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Remove the main cover plate from the ventilator enclosure by removing all screws.
    • Disconnect the battery.
  4. ULCO ntegrus PSV ventilator Battery Replacement: paso 8, imagen 1 de 1
    • Remove the four pan head screws (SM0308P) holding down the battery plate (EV9109) and battery (EV9108) and remove the battery plate and battery.
  5. ULCO ntegrus PSV ventilator Battery Replacement: paso 9, imagen 1 de 1
    • Install the new battery in the same location and screw down the battery plate onto the battery plate spacers so that the battery is firmly held in place.
    • Reconnect the battery.
Conclusión
Preston Myers
Miembro Desde 04/09/20
493 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S7-G13, Paton Spring 2020 Miembro de Cal Poly, Team S7-G13, Paton Spring 2020
CPSU-PATON-S20S7G13
Miembros de 3
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 65
