Herramientas
Partes
No se requieren partes.
  1. Remove bulb and screws in the bulb compartment. Remove bulb and screws in the bulb compartment.
    • Remove bulb and screws in the bulb compartment.
  2. Pry grey ring off from the top or bottom.
    • Pry grey ring off from the top or bottom.
  3. Remove
    • Remove
    • Hole is 3.5" deep. A standard screwdriver will not reach. You need a PH0 or PH1 with a 4" neck.
  4. There are only 2 screws showing in the photo there will be 3.
    • There are only 2 screws showing in the photo there will be 3.
  5. Remove these connectors. There is plenty of slack so it's easy.
    • Remove these connectors. There is plenty of slack so it's easy.
  6. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  7. Remove 8 screws
    • Remove 8 screws
  8. Squeeze to release. Pull to release.
    • Squeeze to release.
    • Pull to release.
    • Slide tabs open to release
  9. Remove Lift out from this side. Some jiggling may be in order.
    • Remove
    • Lift out from this side. Some jiggling may be in order.
    • Power & Ground can be disconnected, but it's not necessary.
  10. Remove 6 screws Remove 6 screws Remove 6 screws
    • Remove 6 screws
    • Rotate counter clockwise and lift simultaneously.
    • Color Wheel is glass.
  11. Remove 2 screws. Lift chip and heatsink away from the main optics unit. Don't lose the spacer and gasket Don't lose the spacer and gasket
    • Remove 2 screws. Lift chip and heatsink away from the main optics unit.
    • Don't lose the spacer and gasket
  12. Rotate ZIF Lock cam to remove chip. You can see the mirrors that have seized up.
    • Rotate ZIF Lock cam to remove chip.
    • You can see the mirrors that have seized up.
  13. Pins are keyed so you it's hard to screw up. Rotate cam lock back to locked position. Put the spacer and then the rubber gasket on top of the optic unit and sit the chip and heat sink on top. That makes it easier to keep everything inline while reassembling.
    • Pins are keyed so you it's hard to screw up.
    • Rotate cam lock back to locked position.
    • Put the spacer and then the rubber gasket on top of the optic unit and sit the chip and heat sink on top. That makes it easier to keep everything inline while reassembling.
    • Snug up your screws.
Conclusión
Tim Wellington
Miembro Desde 21/11/14
217 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 8
