Saltar al contenido principal
Two-Hole Button Replacement
Qué necesitas
  1. Two-Hole Button Replacement, Two-Hole Button: paso 1, imagen 1 de 1
    • Choose a thread that will match the rest of the buttons on the jacket/button.
  2. Two-Hole Button Replacement: paso 2, imagen 1 de 1
    • Thread the needle so that there is equal thread on both sides of the needle.
  3. Two-Hole Button Replacement: paso 3, imagen 1 de 2 Two-Hole Button Replacement: paso 3, imagen 2 de 2
    • Tie a knot at the end of the thread so that it will not come back through the buttonhole.
  4. Two-Hole Button Replacement: paso 4, imagen 1 de 1
    • Place the button on the fabric that you are sewing it back on to.
  5. Two-Hole Button Replacement: paso 5, imagen 1 de 2 Two-Hole Button Replacement: paso 5, imagen 2 de 2
    • Take the threaded needle and push it through the fabric and one of the buttonholes on the bottom side and pull it through.
  6. Two-Hole Button Replacement: paso 6, imagen 1 de 2 Two-Hole Button Replacement: paso 6, imagen 2 de 2
    • Thread the needle down through the second hole of the button.
  7. Two-Hole Button Replacement: paso 7, imagen 1 de 1
    • Place a straight pin on the backside of the button to keep the button from being sewn on too tight.
  8. Two-Hole Button Replacement: paso 8, imagen 1 de 2 Two-Hole Button Replacement: paso 8, imagen 2 de 2
    • Repeat steps 5-6 to continue sewing the button on until secure.
  9. Two-Hole Button Replacement: paso 9, imagen 1 de 2 Two-Hole Button Replacement: paso 9, imagen 2 de 2
    • Once the button is secure, push the needle through the fabric but not the button and remove the pin.
  10. Two-Hole Button Replacement: paso 10, imagen 1 de 2 Two-Hole Button Replacement: paso 10, imagen 2 de 2
    • Once the pin is removed, wrap the thread around the button 6-7 times and push the needle through the fabric on the underside of the button.
  11. Two-Hole Button Replacement: paso 11, imagen 1 de 3 Two-Hole Button Replacement: paso 11, imagen 2 de 3 Two-Hole Button Replacement: paso 11, imagen 3 de 3
    • To finish sewing, make 3-4 stitches to tie off.
  12. Two-Hole Button Replacement: paso 12, imagen 1 de 3 Two-Hole Button Replacement: paso 12, imagen 2 de 3 Two-Hole Button Replacement: paso 12, imagen 3 de 3
    • Cut the remaining thread off.
Conclusión
Test out your fix by closing the jacket/clothing item with your resewn button!
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 117
