Saltar al contenido principal
Turtle Beach Recon Controller Motherboard Replacement
Qué necesitas
  1. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: paso 1, imagen 1 de 3 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: paso 1, imagen 2 de 3 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: paso 1, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Motherboard Replacement: paso 2, imagen 1 de 3 Turtle Beach Recon Controller Motherboard Replacement: paso 2, imagen 2 de 3 Turtle Beach Recon Controller Motherboard Replacement: paso 2, imagen 3 de 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Motherboard Replacement, Face Plate: paso 3, imagen 1 de 2 Turtle Beach Recon Controller Motherboard Replacement, Face Plate: paso 3, imagen 2 de 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Motherboard Replacement: paso 4, imagen 1 de 2 Turtle Beach Recon Controller Motherboard Replacement: paso 4, imagen 2 de 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Motherboard Replacement: paso 5, imagen 1 de 3 Turtle Beach Recon Controller Motherboard Replacement: paso 5, imagen 2 de 3 Turtle Beach Recon Controller Motherboard Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: paso 6, imagen 1 de 2 Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: paso 6, imagen 2 de 2
    • Use your fingers to lift both of the joystick caps off of the motherboard.
    • Remove the joystick caps.
  7. Turtle Beach Recon Controller Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Nothing can be further removed from the motherboard. It can now be replaced.
Conclusión
2 personas más completaron esta guía.
Mary Goodrow
Miembro Desde 03/22/24
671 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 6-1, Botvin Spring 2024 Miembro de UMass Dartmouth, Team 6-1, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G1
Miembros de 3
5 Guías creadas
1Guía Comentario
thanks for posting this!
Sean Malter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 45
Todo El Tiempo: 627
