Introducción
This guide outlines the steps to replace the thumb sticks on your REACT-R controller, Worn or drifting thumb sticks can greatly affect your gaming experience, making replacements necessary to maintain accuracy and responsiveness.
For this procedure, you will need a Phillips #00 screwdriver. Follow this guide carefully to replace the thumb sticks to your REACT-R controller.
Qué necesitas
Place the controller face down.
Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
Use both hands to lift the backplate away from the controller.
Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
Gently lift the motherboard up and out of the chassis.
Gently twist off each thumb stick, using one hand to secure the base, and the other to twist off the thumb stick.
2 personas más completaron esta guía.
