Saltar al contenido principal
Turtle Beach Ear Force X12 Slide Adjustment Replacement
Qué necesitas
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: paso 1, imagen 1 de 1
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: paso 2, imagen 1 de 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: paso 2, imagen 2 de 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
Conclusión
Katha Patel
Miembro Desde 10/02/17
218 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G3, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G3, Thompson Fall 2017
USFT-THOMPSON-F17S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 538
