Saltar al contenido principal
Tungsten E Battery Replacement
Qué necesitas
  1. Tungsten E Battery Replacement, Battery: paso 1, imagen 1 de 1
  2. Tungsten E Battery Replacement: paso 2, imagen 1 de 1
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Tungsten E Battery Replacement: paso 3, imagen 1 de 1
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  4. Tungsten E Battery Replacement: paso 4, imagen 1 de 1
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  5. Tungsten E Battery Replacement: paso 5, imagen 1 de 1
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
Conclusión
Una persona más ha completado esta guía.
Kathleen Hix
Miembro Desde 01/21/10
49 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-22, Maness Winter 2010 Miembro de Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 6,695
