Qué necesitas
Flip over the controller.
Then, unscrew the 7 screws holding it together.
There are no screws hiding under the sticker, so there is no need to rip it off or punch a hole in it (like i tried to do in a previous attempt)
After removing the screws, just pull the back off of the controller. There aren't any cables attached to it.
First, unplug the battery connector
Then, undo the 8 clips that hold the board to the front casing with the flathead driver.
After that, just lift the board up.
To remove the vibration motors, just pull them out, being careful not to break the wires.
Remove the screws holding the D-pad and buttons to the front case, carefully prying them out with your flathead. To remove the shoulder buttons, just pull them out.
Unfortunately, the clear lenses through which the status LEDs shine are glued onto the case and are not removable.
5 personas más completaron esta guía.
Un comentario
Hello, I got this one (wired version) and I want to change joysticks as they are pretty much trash for analog control (joystick sensitivity). I want to use potenciometer ones as they are mostly used in premium brands such as microsoft and sony. What can I use? are there any things to be aware of? Any compatibility issues? I know how to disassemble it and solder it on. I just need to know which to get. I found ones from local shop called "Potenciometr Joystick PS4 JDM-055". ******Thanks for any response and have a great day :)
