Saltar al contenido principal
Trio Stealth-Mini Screen Replacement
Qué necesitas
  1. Trio Stealth-Mini Screen Replacement, Battery: paso 1, imagen 1 de 2 Trio Stealth-Mini Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the indentation at the bottom of the device.
  2. Trio Stealth-Mini Screen Replacement: paso 2, imagen 1 de 3 Trio Stealth-Mini Screen Replacement: paso 2, imagen 2 de 3 Trio Stealth-Mini Screen Replacement: paso 2, imagen 3 de 3
    • Pull on the indentation and take off the casing of the device.
  3. Trio Stealth-Mini Screen Replacement: paso 3, imagen 1 de 2 Trio Stealth-Mini Screen Replacement: paso 3, imagen 2 de 2
    • Remove the faulty battery and insert a replacement in its slot.
  4. Trio Stealth-Mini Screen Replacement, Screen: paso 4, imagen 1 de 1
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Trio Stealth-Mini Screen Replacement: paso 5, imagen 1 de 1
    • Remove inner casing exposing the motherboard.
  6. Trio Stealth-Mini Screen Replacement: paso 6, imagen 1 de 2 Trio Stealth-Mini Screen Replacement: paso 6, imagen 2 de 2
    • Remove speakers by peeling back yelllow tape.
  7. Trio Stealth-Mini Screen Replacement: paso 7, imagen 1 de 1
    • Remove ribbon cable on top of motherboard.
  8. Trio Stealth-Mini Screen Replacement: paso 8, imagen 1 de 1
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  9. Trio Stealth-Mini Screen Replacement: paso 9, imagen 1 de 1
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  10. Trio Stealth-Mini Screen Replacement: paso 10, imagen 1 de 1
    • Verify that all screws are detached from screen.
  11. Trio Stealth-Mini Screen Replacement: paso 11, imagen 1 de 1
    • Detach screen from main assembly.
Conclusión
Stewart Jenkins
Miembro Desde 03/26/18
207 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G1, Harley Spring 2018 Miembro de IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Miembros
6 Guías creadas
Un comentario
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 224
