Saltar al contenido principal
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
Qué necesitas
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: paso 2, imagen 1 de 1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: paso 3, imagen 1 de 1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: paso 5, imagen 1 de 1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 1-4, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 418
