Saltar al contenido principal
Trio Stealth G2 Hype Back Panel Replacement
Qué necesitas
  1. Trio Stealth G2 Hype Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Trio Stealth G2 Hype Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Back Panel Replacement: paso 2, imagen 1 de 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Back Panel Replacement: paso 3, imagen 1 de 3 Trio Stealth G2 Hype Back Panel Replacement: paso 3, imagen 2 de 3 Trio Stealth G2 Hype Back Panel Replacement: paso 3, imagen 3 de 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
Conclusión
Equipo
USF Tampa, Team 4-4, Brown Winter 2015 Miembro de USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 682
