Introducción
This Motherboard you will be fixing/replacing will contain sensitive electronic parts, so be very careful!
Qué necesitas
To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
Apply heat and solder to each lead individually.
Remove any excess solder if flooding occurs.
Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
Remove any excess solder as needed.
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
2 personas más completaron esta guía.
