Saltar al contenido principal
Trio STEALTH-9 Camera Replacement
Qué necesitas
  1. Trio STEALTH-9 Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Camera Replacement: paso 2, imagen 1 de 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Camera Replacement: paso 3, imagen 1 de 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Camera Replacement: paso 4, imagen 1 de 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
  5. Trio STEALTH-9 Camera Replacement, Camera: paso 5, imagen 1 de 2 Trio STEALTH-9 Camera Replacement, Camera: paso 5, imagen 2 de 2
    • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
  6. Trio STEALTH-9 Camera Replacement: paso 6, imagen 1 de 2 Trio STEALTH-9 Camera Replacement: paso 6, imagen 2 de 2
    • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
  7. Trio STEALTH-9 Camera Replacement: paso 7, imagen 1 de 2 Trio STEALTH-9 Camera Replacement: paso 7, imagen 2 de 2
    • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
    • Remove the camera from the frame and replace as needed.
Conclusión
[deleted]
Miembro Desde 01/29/15
415 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 142
