Saltar al contenido principal
Trio STEALTH-9 Back Cover Replacement
Qué necesitas
  1. Trio STEALTH-9 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Back Cover Replacement: paso 2, imagen 1 de 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Back Cover Replacement: paso 3, imagen 1 de 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Back Cover Replacement: paso 4, imagen 1 de 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
Conclusión
To reassemble your device, follow these instructions in reverse order with your replacement cover!
2 personas más completaron esta guía.
Mei Liang
Miembro Desde 01/29/15
228 Reputación
2 Guías creadas
Equipo
Clemson, Team 15-5, Shirley Winter 2015 Miembro de Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Miembros
4 Guías creadas
2 comentarios
Tengo.una y costo tiene el.displey
eliehtmaria - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,164
