Saltar al contenido principal
Trio AXS 3G Battery Replacement
Qué necesitas
  1. Trio AXS 3G Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Battery Replacement: paso 2, imagen 1 de 2 Trio AXS 3G Battery Replacement: paso 2, imagen 2 de 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Battery Replacement: paso 3, imagen 1 de 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Battery Replacement, Battery: paso 4, imagen 1 de 1
    • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
  5. Trio AXS 3G Battery Replacement: paso 5, imagen 1 de 1
    • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
  6. Trio AXS 3G Battery Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Use the plastic card to pry the battery away from the device.
    • The battery is attached to the tablet by glue.
  7. Trio AXS 3G Battery Replacement: paso 7, imagen 1 de 1
    • Peel off the battery from the device to completely remove it.
Conclusión
2 personas más completaron esta guía.
2 comentarios
where can i buy a battery replacement? can it work without a battery?
millie abanilla - Contestar
where can you buy a replacement battery
J W - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 1,304
