Saltar al contenido principal
Trio AXS 3G Back Case Replacement
Qué necesitas
  1. Trio AXS 3G Back Case Replacement, Back Case: paso 1, imagen 1 de 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Back Case Replacement: paso 2, imagen 1 de 2 Trio AXS 3G Back Case Replacement: paso 2, imagen 2 de 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Back Case Replacement: paso 3, imagen 1 de 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
Conclusión
0 Guide Comments
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 369
