Peligro
Potencialmente Peligroso
Una lesión puede resultar si este procedimiento no se sigue correctamente. Ten precaución y sigue todas las advertencias.
Peligro
Introducción
When your brakes get worn down, they need to be replaced. This will help keep you safe as you ride.
Partes
No se requieren partes.
  1. Note: In this repair guide the pictures are taken with the tire removed so that it is easier to follow our steps. However, removing the tire is not necessary to replace the brake pads. Unscrew the brake pad cap with a T25 screwdriver bit.
    • Note: In this repair guide the pictures are taken with the tire removed so that it is easier to follow our steps. However, removing the tire is not necessary to replace the brake pads.
    • Unscrew the brake pad cap with a T25 screwdriver bit.
  2. Grab and pull out the spring between the brake pads. Grab and pull out the spring between the brake pads. Grab and pull out the spring between the brake pads.
    • Grab and pull out the spring between the brake pads.
  3. Slide out the back brake pad first. Then slide out the front brake pad. Slide out the back brake pad first. Then slide out the front brake pad. Slide out the back brake pad first. Then slide out the front brake pad.
    • Slide out the back brake pad first. Then slide out the front brake pad.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Slide in the new brake pads with the first going in the front. Slide in the new brake pads with the first going in the front.
    • Slide in the new brake pads with the first going in the front.
  6. Then slide in the other pad in the back. Make sure each brake pad is facing the right way. Make sure each brake pad is facing the right way.
    • Then slide in the other pad in the back.
    • Make sure each brake pad is facing the right way.
  7. Push the spring back into place between the two brake pads so the spring is visible in the hole shown here. Push the spring back into place between the two brake pads so the spring is visible in the hole shown here. Push the spring back into place between the two brake pads so the spring is visible in the hole shown here.
    • Push the spring back into place between the two brake pads so the spring is visible in the hole shown here.
  8. Screw the brake pad cap back on. Screw the brake pad cap back on.
    • Screw the brake pad cap back on.
  9. Adjust the red knob as necessary (directions are noted on the knob).
    • Adjust the red knob as necessary (directions are noted on the knob).
Conclusión
Now your bike should actually be able to stop.
Ben Hartinger
Miembro Desde 27/01/14
340 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-37, Maness Winter 2014 Miembro de Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 280
