Saltar al contenido principal
Trek Neko Bike Brake Pad Replacement
Qué necesitas
  1. Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: paso 1, imagen 1 de 2 Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: paso 1, imagen 2 de 2
    • Squeeze the two brake arms together.
    • Angle the brake noodle down.
    • Push the quick release down to release the brake noodle.
  2. Trek Neko Bike Brake Pad Replacement: paso 2, imagen 1 de 1
    • Flip the bike over so that the seat is on the ground.
  3. Trek Neko Bike Brake Pad Replacement: paso 3, imagen 1 de 3 Trek Neko Bike Brake Pad Replacement: paso 3, imagen 2 de 3 Trek Neko Bike Brake Pad Replacement: paso 3, imagen 3 de 3
    • Open the quick release lever on the bike wheel.
    • Rotate the lever in a counter clockwise direction to loosen the wheel.
    • Remove the wheel from the bike frame.
  4. Trek Neko Bike Brake Pad Replacement: paso 4, imagen 1 de 2 Trek Neko Bike Brake Pad Replacement: paso 4, imagen 2 de 2
    • Loosen the locking bolt on the brake pad with a 5 mm Allen wrench.
    • Remove the locking bolt, washers, and brake pad from the brake pad housing.
  5. Trek Neko Bike Brake Pad Replacement: paso 5, imagen 1 de 2 Trek Neko Bike Brake Pad Replacement: paso 5, imagen 2 de 2
    • Insert the new brake pad.
    • Insert the washers.
    • Insert the locking bolt.
  6. Trek Neko Bike Brake Pad Replacement: paso 6, imagen 1 de 2 Trek Neko Bike Brake Pad Replacement: paso 6, imagen 2 de 2
    • Tighten the brake pad locking bolt bolt clockwise until it is finger tight.
    • Tighten the bolt with a 5 mm Allen wrench.
  7. Trek Neko Bike Brake Pad Replacement: paso 7, imagen 1 de 3 Trek Neko Bike Brake Pad Replacement: paso 7, imagen 2 de 3 Trek Neko Bike Brake Pad Replacement: paso 7, imagen 3 de 3
    • Reinsert the wheel.
    • Tighten the bolt on the wheel until it is finger tight.
    • Center the wheel in the frame.
    • Close the quick release lever to secure the wheel.
  8. Trek Neko Bike Brake Pad Replacement: paso 8, imagen 1 de 2 Trek Neko Bike Brake Pad Replacement: paso 8, imagen 2 de 2
    • Place the bike right side up.
  9. Trek Neko Bike Brake Pad Replacement: paso 9, imagen 1 de 3 Trek Neko Bike Brake Pad Replacement: paso 9, imagen 2 de 3 Trek Neko Bike Brake Pad Replacement: paso 9, imagen 3 de 3
    • Insert the brake noodle into the quick release lever.
    • Angle the quick release lever upwards so that the brake noodle clicks into place.
  10. Trek Neko Bike Brake Pad Replacement: paso 10, imagen 1 de 2 Trek Neko Bike Brake Pad Replacement: paso 10, imagen 2 de 2
    • Squeeze the brakes to check proper fitment.
    • Tighten or loosen the quick release bolt on the brake arms to adjust based on preference.
Conclusión
With properly installed brake pads, you can now safely ride your bike!
Una persona más ha completado esta guía.
Camille Nikaido
Miembro Desde 02/02/23
181 Reputación
1 Guía escrita
Equipo
UC Davis, Team 1-9, Andersen Winter 2023 Miembro de UC Davis, Team 1-9, Andersen Winter 2023
UCD-ANDERSEN-W23S1G9
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 246
