Saltar al contenido principal
Trek 820 Tail Light Mounting Bracket Replacement
Qué necesitas
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: paso 1, imagen 1 de 1
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: paso 2, imagen 1 de 1
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: paso 3, imagen 1 de 2 Trek 820 Tail Light Mounting Bracket Replacement: paso 3, imagen 2 de 2
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: paso 4, imagen 1 de 2 Trek 820 Tail Light Mounting Bracket Replacement: paso 4, imagen 2 de 2
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Conclusión
Equipo
Cal Poly, Team 1-1, Propen Fall 2012 Miembro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,139
