Saltar al contenido principal
Trek 820 Handlebars Replacement
Qué necesitas
  1. Trek 820 Handlebars Replacement, Handlebar and stem: paso 1, imagen 1 de 2 Trek 820 Handlebars Replacement, Handlebar and stem: paso 1, imagen 2 de 2
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: paso 2, imagen 1 de 1
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: paso 3, imagen 1 de 2 Trek 820 Handlebars Replacement: paso 3, imagen 2 de 2
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
  4. Trek 820 Handlebars Replacement: paso 4, imagen 1 de 2 Trek 820 Handlebars Replacement: paso 4, imagen 2 de 2
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: paso 5, imagen 1 de 1
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
Conclusión
Equipo
Cal Poly, Team 1-1, Propen Fall 2012 Miembro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Miembros
9 Guías creadas
Un comentario
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 50
Todo El Tiempo: 5,802
