Saltar al contenido principal
Traxxas Summit Steering Assembly Servo Replacement
Qué necesitas
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: paso 1, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: paso 1, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: paso 1, imagen 3 de 3
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: paso 2, imagen 1 de 2 Traxxas Summit Steering Assembly Servo Replacement: paso 2, imagen 2 de 2
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: paso 3, imagen 1 de 2 Traxxas Summit Steering Assembly Servo Replacement: paso 3, imagen 2 de 2
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: paso 4, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 4, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 4, imagen 3 de 3
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: paso 5, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 5, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 5, imagen 3 de 3
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: paso 6, imagen 1 de 2 Traxxas Summit Steering Assembly Servo Replacement: paso 6, imagen 2 de 2
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: paso 7, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 7, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 7, imagen 3 de 3
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: paso 8, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 8, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 8, imagen 3 de 3
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: paso 9, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 9, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 9, imagen 3 de 3
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: paso 10, imagen 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 10, imagen 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: paso 10, imagen 3 de 3
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 2,286
