Saltar al contenido principal
Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly
Qué necesitas
  1. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly, Traxxas Stampede 12T Brushed Motor: paso 1, imagen 1 de 1
    • Remove the fastner clips on all four corners of the body.
  2. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 2, imagen 1 de 1
    • Lifting straight up, remove the plastic body from the truck, exposing the inner components.
  3. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 3, imagen 1 de 1
    • Using a Phillips #1 screwdriver, on the rear right side, remove the center screw from the green wheelie bar.
  4. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 4, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the center screw on the left side of the green wheelie bar.
  5. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 5, imagen 1 de 2 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 5, imagen 2 de 2
    • Pull the black power wire in an outward motion on both sides of the clear plastic sleeve to disconnect the motor from the battery. Repeat this with the red power wire to disconnect it from the battery.
  6. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 6, imagen 1 de 2 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 6, imagen 2 de 2
    • Remove the right rear wheel, using a 7.0 mm socket-or R.C. wheel wrench to loosen the Nyloc nut.
    • Pull the wheel straight out removing it from the truck.
  7. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 7, imagen 1 de 2 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 7, imagen 2 de 2
    • Using a number Phillips #1 screwdriver, remove the two screws that hold the plastic motor housing together.
    • Pull the motor housing straight out and remove.
  8. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 8, imagen 1 de 2 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 8, imagen 2 de 2
    • Using a 1/16 Allen wrench, loosen the set screw inside the small gear that holds the motor in place.
    • Pull straight out to remove the gear from the motor shaft.
  9. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 9, imagen 1 de 1
    • Remove two Phillips #1 head screws holding the motor in place.
  10. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 10, imagen 1 de 2 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: paso 10, imagen 2 de 2
    • Grasping the motor, slide it out towards the left tire, removing it entirely.
    • Now you have removed the old motor and can replace it with a new one.
Conclusión
Ashley
Miembro Desde 10/08/19
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 720
