Introducción
In the situation where the motor in a Traxxas Ford Fiesta ST Rally fails due to natural wear, lack of maintenance, or is somehow defective, the user may need to remove the motor and replace it with a functioning motor. The process will not take long and will only require the use of standard hex keys. This guide will provide a walkthrough of the process of removing the broken motor and installing a new one that can be ordered online or bought at a hobby store. Before using this guide, please disconnect the battery in the chassis and ensure that any dust or dirt will not pose a hazard to components before completing the fix. Any hazardous dirt can often be removed with canned air, a duster, or lightly shaking the dirt off holding the chassis upside down.
Qué necesitas
Remove each of the four pins that hold the scale model shell by pulling them from their posts.
Remove the shell by lifting it off the chassis using your hands.
Follow these instructions in reverse order to reassemble your device using the new/functioning motor.
