Saltar al contenido principal
Traxxas Ford Fiesta ST Rally Motor Replacement
Qué necesitas
  1. Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: paso 1, imagen 1 de 3 Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: paso 1, imagen 2 de 3 Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: paso 1, imagen 3 de 3
    • Remove each of the four pins that hold the scale model shell by pulling them from their posts.
    • Remove the shell by lifting it off the chassis using your hands.
  2. Traxxas Ford Fiesta ST Rally Motor Replacement: paso 2, imagen 1 de 2 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 2, imagen 2 de 2
    • Remove the 3x6 mm screw holding the wire retainer in place using a 2.5 mm hex key.
    • Remove the wire retainer by lifting it off the chassis.
  3. Traxxas Ford Fiesta ST Rally Motor Replacement: paso 3, imagen 1 de 2 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 3, imagen 2 de 2
    • This guide was done without a battery present. Please remember to properly disconnect any batteries before this step as it could cause injury to you or damage to the device.
    • Disconnect both power cables attaching the electronic speed control to the motor.
  4. Traxxas Ford Fiesta ST Rally Motor Replacement: paso 4, imagen 1 de 2 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 4, imagen 2 de 2
    • Remove the 3x15 mm retaining bolt using the 3 mm hex key.
    • Remove the 3x6 mm flat head screw holding the motor plate in place with the 3 mm hex key.
  5. Traxxas Ford Fiesta ST Rally Motor Replacement: paso 5, imagen 1 de 2 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 5, imagen 2 de 2
    • Use the 2.5 mm hex key to remove the 3x6 mm screw for the gear cover.
    • To remove the cover, simply lift it up and off of the chassis.
    • During reassembly, ensure that the motor and gearing line up just how it is in the second photo for this step.
  6. Traxxas Ford Fiesta ST Rally Motor Replacement: paso 6, imagen 1 de 3 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 6, imagen 2 de 3 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 6, imagen 3 de 3
    • Remove the motor by rotating and lifting it free from the chassis.
    • You may need to clean the area where the new motor will be to prevent the possibility of debris becoming a problem for a newly replaced engine.
  7. Traxxas Ford Fiesta ST Rally Motor Replacement: paso 7, imagen 1 de 3 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 7, imagen 2 de 3 Traxxas Ford Fiesta ST Rally Motor Replacement: paso 7, imagen 3 de 3
    • Use the 2.5 mm hex key to loosen the 3x8 mm screws to remove the motor plate.
    • Use the 2 mm hex key to loosen the 3 mm grub screw enough to remove the pinion gear from the motor.
    • Slide the pinion gear right off the motor's external rod when loose enough.
    • Make sure to have the pinion gear in the exact same area as it was on the replaced motor in order to align with the device's gearing.
    • This process can also be used to put an even better motor in as a replacement during reassembly.
Conclusión
Follow these instructions in reverse order to reassemble your device using the new/functioning motor.
Joshua Bailey
Miembro Desde 01/28/22
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 539
