Qué necesitas
This car has no easy lifting points, and a bodykit and low ground clearance makes lifting a bit harder
I was able to come in from behind the front wheels at the sides and lift from the box section of the unibody as pictured
The jack-stands I placed hard up against the jack and found a spot on the "frame-rails" (box section of unibody)
I like to use cardboard, but a shop creeper would work too
The oilpan and drain bolt are located at the right-front of the car
The oil filter is faced downwards and is just in front of the oil pan under the intake manifold
You don't need to take off the plastic under-shield but if it's annoying you could
The drain bolt on the 1.3L engine is a 14mm
Re-position the pan as it drains - especially if it's a windy day
I like to use a set of oil-filter pliers but a correct oil filter socket would be a luxury, or a strap wrench or other tool would be fine
Make SURE the gasket comes off with the old filter and is NOT stuck on the block
Oil up your new filter's gasket
Since the oil filter is facing down, you can pre-fill the oil filter if you like, it can be messy if you drop it though!
Clean the mating surface with rags before installing the new filter
Tighten the filter 3/4 turn after it touches the block
Remember to also tighten the oil drain bolt, and clean around each area with rags so you can spot leaks easier
Remove cardboard/creeper and any tools
Lift each side and remove the jack stand
Lower the car which will level it for filling
The fill cap and dipstick are located at the front-right of the car (left side of engine bay)
I used 10W-40 full synthetic oil, and the car accepted around 3.8L
I like to use a stubby wide-mouth funnel
Sorry I didn't take any photos of this step as it was the end of a long day of 3x cars servicing
Run the car for 15 seconds or so to fill the filter and oil galleries
Turn off the car and check for leaks underneath
Check the level again with the dipstick and top up as required
Servicing Done!
Servicing Done!
2 personas más completaron esta guía.
