Saltar al contenido principal
Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement
Qué necesitas
  1. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Unscrew the front bumper: paso 1, imagen 1 de 2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Unscrew the front bumper: paso 1, imagen 2 de 2
    • Unscrew the cross-head screws which attach the front bumper to the car.
    • There are 4 screws to remove.
    • If you're only changing one headlight you need only unscrew one side. But for your peace of mind I'd advise you to remove them all.
  2. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Wheel arch screw: paso 2, imagen 1 de 2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Wheel arch screw: paso 2, imagen 2 de 2
    • Unscrew the cross-head screw in the wheel arch.
    • You can use either a spanner, or a cross-head screwdriver.
  3. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Central bumper attachment: paso 3, imagen 1 de 2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Central bumper attachment: paso 3, imagen 2 de 2
    • Release the plastic clip which attaches the top of the bumper to the middle of the radiator grill.
  4. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Bumper removal: paso 4, imagen 1 de 3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Bumper removal: paso 4, imagen 2 de 3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Bumper removal: paso 4, imagen 3 de 3
    • Disengage the the bumper attachment.
    • Using a large screwdriver or a small iron bar, lever it as shown until it detaches.
    • There are 2 attachments to release either side of the bonnet lock.
    • If you're only changing one headlight you only need to detach one side.
    • Completely disengage the bumper from around the headlight, pulling it gently outwards.
  5. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: paso 5, imagen 1 de 2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: paso 5, imagen 2 de 2
    • Remove the cross-head screw on the side of the headlight (at the front).
    • Also remove the cross-head screw from the top of the headlight.
  6. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: paso 6, imagen 1 de 2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement: paso 6, imagen 2 de 2
    • Lift the top attachment of the headlight.
    • Disengage the headlamp, pulling it forwards.
    • Be careful - the bulbs are still connected. Don't pull the headlight too far forward.
  7. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Indicator bulb: paso 7, imagen 1 de 2 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Indicator bulb: paso 7, imagen 2 de 2
    • Turn the indicator bulb connector a quarter turn counter-clockwise.
    • Remove the indicator bulb.
  8. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Main beam bulb: paso 8, imagen 1 de 1
    • Withdraw the rubber boot on the back of the main beam bulb.
    • Unclip the clip which attaches the main beam bulb and remove the main beam bulb.
  9. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Side light: paso 9, imagen 1 de 1
    • Twist the side light connector a quarter towards counter-clockwise.
    • Withdraw the side light.
  10. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Dip motor: paso 10, imagen 1 de 1
    • Twist headlight dip motor a quarter towards counter-clockwise.
    • Withdraw the dip motor.
    • On reassembly, take care to secure the motor properly in position. An adjustment may prove necessary to ensure the position of the dashboard control corresponds to the correct level of dip.
  11. Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Reassembly notes: paso 11, imagen 1 de 3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Reassembly notes: paso 11, imagen 2 de 3 Toyota Yaris (Echo) 1999-2005 optical headlight unit replacement, Reassembly notes: paso 11, imagen 3 de 3
    • To reassemble your headlight, take care to correctly position the headlight, before reassembling the bulbs, dip motor, and screws.
    • Make sure the plastic pin on the side of the headlamp is properly inserted into the bodywork.
Conclusión
To reassemble, follow the steps in reverse order.
4 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
2 comentarios
Merci beaucoup pour ce tuto qui nous a bien servi.
Isabelle Gueguen - Contestar
Merci pour le tutoriel qui m'a été d'une grande aide !
Sevan KEVORKIAN - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 55
Ultimos 30 días: 197
Todo El Tiempo: 15,540
