Introducción
Warning:
You can disassemble the instrument cluster for a neater solution, however beware, the buzzer is linked to the ECU so any electrical circuit modifications like actually disconnecting the buzzer could lead to a ECU malfunction.
Partes
No se requieren partes.
  1. Start by removing the hood over the instrument cluster. Pull the hood straight out towards the steering wheel. Start by removing the hood over the instrument cluster. Pull the hood straight out towards the steering wheel.
    • Start by removing the hood over the instrument cluster. Pull the hood straight out towards the steering wheel.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  3. After removing the hood, undo the four screws securing the instrument cluster and pull forward. After removing the hood, undo the four screws securing the instrument cluster and pull forward.
    • After removing the hood, undo the four screws securing the instrument cluster and pull forward.
    • The buzzer is accessed through a grill in the bottom of the instrument cluster/combination meter. Simply poke a sharp object into the grill and mash up the speaker dome to neutralize the buzzer!
Conclusión
6 personas más completaron esta guía.
bt1993
Miembro Desde 13/02/13
345 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 8
Últimos 30 Días: 45
Todo El Tiempo: 4,847
