Saltar al contenido principal
Toyota Corolla 2018 Brake Light Replacement
Qué necesitas
  1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: paso 1, imagen 1 de 2 Toyota Corolla 2018 Brake Light Replacement, Brake Light: paso 1, imagen 2 de 2
    • Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
  2. Toyota Corolla 2018 Brake Light Replacement: paso 2, imagen 1 de 2 Toyota Corolla 2018 Brake Light Replacement: paso 2, imagen 2 de 2
    • Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
    • The rear turn signal bulb is located at the top and has a grey cap.
    • The brake light is located at the bottom and has an orange cap.
  3. Toyota Corolla 2018 Brake Light Replacement: paso 3, imagen 1 de 2 Toyota Corolla 2018 Brake Light Replacement: paso 3, imagen 2 de 2
    • Turn the brake light counterclockwise and pull the old light straight out of the socket.
  4. Toyota Corolla 2018 Brake Light Replacement: paso 4, imagen 1 de 1
    • Replace the new bulb and push it in the socket.
  5. Toyota Corolla 2018 Brake Light Replacement: paso 5, imagen 1 de 1
    • Turn the socket clockwise while placing it in the housing.
  6. Toyota Corolla 2018 Brake Light Replacement: paso 6, imagen 1 de 2 Toyota Corolla 2018 Brake Light Replacement: paso 6, imagen 2 de 2
    • Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 24
Ultimos 30 días: 100
Todo El Tiempo: 3,727
