Saltar al contenido principal
Toy Lightsaber Battery Replacement
Qué necesitas
  1. Toy Lightsaber Battery Replacement, Battery: paso 1, imagen 1 de 3 Toy Lightsaber Battery Replacement, Battery: paso 1, imagen 2 de 3 Toy Lightsaber Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: paso 2, imagen 1 de 3 Toy Lightsaber Battery Replacement: paso 2, imagen 2 de 3 Toy Lightsaber Battery Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: paso 3, imagen 1 de 3 Toy Lightsaber Battery Replacement: paso 3, imagen 2 de 3 Toy Lightsaber Battery Replacement: paso 3, imagen 3 de 3
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: paso 4, imagen 1 de 3 Toy Lightsaber Battery Replacement: paso 4, imagen 2 de 3 Toy Lightsaber Battery Replacement: paso 4, imagen 3 de 3
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: paso 5, imagen 1 de 3 Toy Lightsaber Battery Replacement: paso 5, imagen 2 de 3 Toy Lightsaber Battery Replacement: paso 5, imagen 3 de 3
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: paso 6, imagen 1 de 3 Toy Lightsaber Battery Replacement: paso 6, imagen 2 de 3 Toy Lightsaber Battery Replacement: paso 6, imagen 3 de 3
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
Conclusión
Una persona más ha completado esta guía.
Zachary Adaes
Miembro Desde 03/22/21
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 63
Todo El Tiempo: 3,537
