Saltar al contenido principal
Toto E-Max Fill Valve Disassembly
Qué necesitas
  1. Toto E-Max Fill Valve Disassembly, Tank Lid: paso 1, imagen 1 de 3 Toto E-Max Fill Valve Disassembly, Tank Lid: paso 1, imagen 2 de 3 Toto E-Max Fill Valve Disassembly, Tank Lid: paso 1, imagen 3 de 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: paso 2, imagen 1 de 2 Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: paso 2, imagen 2 de 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toto E-Max Fill Valve Disassembly, Refill Tube: paso 3, imagen 1 de 3 Toto E-Max Fill Valve Disassembly, Refill Tube: paso 3, imagen 2 de 3 Toto E-Max Fill Valve Disassembly, Refill Tube: paso 3, imagen 3 de 3
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
  4. Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: paso 4, imagen 1 de 2 Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: paso 4, imagen 2 de 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  5. Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: paso 5, imagen 1 de 3 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: paso 5, imagen 2 de 3 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: paso 5, imagen 3 de 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  6. Toto E-Max Fill Valve Disassembly, Supply Tube: paso 6, imagen 1 de 3 Toto E-Max Fill Valve Disassembly, Supply Tube: paso 6, imagen 2 de 3 Toto E-Max Fill Valve Disassembly, Supply Tube: paso 6, imagen 3 de 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  7. Toto E-Max Fill Valve Disassembly, Fill Valve: paso 7, imagen 1 de 2 Toto E-Max Fill Valve Disassembly, Fill Valve: paso 7, imagen 2 de 2
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
  8. Toto E-Max Fill Valve Disassembly: paso 8, imagen 1 de 3 Toto E-Max Fill Valve Disassembly: paso 8, imagen 2 de 3 Toto E-Max Fill Valve Disassembly: paso 8, imagen 3 de 3
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
  9. Toto E-Max Fill Valve Disassembly: paso 9, imagen 1 de 2 Toto E-Max Fill Valve Disassembly: paso 9, imagen 2 de 2
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
  10. Toto E-Max Fill Valve Disassembly, Toto E-Max Fill Valve Disassembly: paso 10, imagen 1 de 1
    • This is our friend the Toto E-Max Fill valve. Unfortunately, she is leaking. Specifically, the shutoff is incomplete, so water continues to flow even after the float is fully lifted.
  11. Toto E-Max Fill Valve Disassembly, Remove Top Cap: paso 11, imagen 1 de 1
    • The next step is to remove the green top cap. It's held on by tabs, light flexing should allow you to remove it.
  12. Toto E-Max Fill Valve Disassembly, Remove the valve lever: paso 12, imagen 1 de 1
    • Here is the valve lever[*]. We need to remove it. It's held in by two pegs. Each one is attached to a flexible tang. use a thin blade or screwdriver to push each tang in, while gently lifting the lever.
    • [*} I have no idea if this is the right name.
  13. Toto E-Max Fill Valve Disassembly, Continue removing valve lever: paso 13, imagen 1 de 1
    • Here we see one peg released. Note that I'm applying very gentle lifting pressure, not prying it upward.
  14. Toto E-Max Fill Valve Disassembly, Release one end of valve lever: paso 14, imagen 1 de 1
    • Valve lever released! You are a champion. BTW, I made up the name "valve lever". I hope you're not laughing at me.
  15. Toto E-Max Fill Valve Disassembly, Release other end of valve lever: paso 15, imagen 1 de 1
    • This is the other end of the valve lever. You should be able to easily release it from the green collar.
  16. Toto E-Max Fill Valve Disassembly, Remove the collar: paso 16, imagen 1 de 1
    • Next, gently pop off the green collar that links the valve lever to the threaded float lift shaft.
  17. Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: paso 17, imagen 1 de 2 Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: paso 17, imagen 2 de 2
    • Gently snap the white float pole out of the jaws of the top cap. When you do this, the float assembly will drop.
  18. Toto E-Max Fill Valve Disassembly, Rotate valve cover: paso 18, imagen 1 de 1
    • Rotate the valve cover an eighth of a turn counter-clockwise to release it.
  19. Toto E-Max Fill Valve Disassembly, Admire valve seal: paso 19, imagen 1 de 2 Toto E-Max Fill Valve Disassembly, Admire valve seal: paso 19, imagen 2 de 2
    • Yay! We got to the valve seal. Clean it off or replace it, and reverse steps to reassemble.
Conclusión
3 personas más completaron esta guía.
John Clements
Miembro Desde 11/05/17
504 Reputación
2 Guías creadas
Un comentario
Thank you! I did not expect to find a guide for a Toto toilet repair on a (mainly) electronics site, but here it is!
It worked perfectly when my toilet started running continuously on a Saturday evening.
I was able to take everything apart without even removing it from the tank, so it was a 15min fix!
Thank you!
Graham Allen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 76
Todo El Tiempo: 2,245
