Saltar al contenido principal
Toshiba Thrive Front Camera Replacement
Qué necesitas
  1. Toshiba Thrive Front Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Front Camera Replacement: paso 2, imagen 1 de 2 Toshiba Thrive Front Camera Replacement: paso 2, imagen 2 de 2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Front Camera Replacement: paso 3, imagen 1 de 1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Front Camera Replacement: paso 4, imagen 1 de 3 Toshiba Thrive Front Camera Replacement: paso 4, imagen 2 de 3 Toshiba Thrive Front Camera Replacement: paso 4, imagen 3 de 3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Front Camera Replacement, Midframe: paso 5, imagen 1 de 2 Toshiba Thrive Front Camera Replacement, Midframe: paso 5, imagen 2 de 2
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Front Camera Replacement: paso 6, imagen 1 de 3 Toshiba Thrive Front Camera Replacement: paso 6, imagen 2 de 3 Toshiba Thrive Front Camera Replacement: paso 6, imagen 3 de 3
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Front Camera Replacement: paso 7, imagen 1 de 3 Toshiba Thrive Front Camera Replacement: paso 7, imagen 2 de 3 Toshiba Thrive Front Camera Replacement: paso 7, imagen 3 de 3
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Front Camera Replacement: paso 8, imagen 1 de 2 Toshiba Thrive Front Camera Replacement: paso 8, imagen 2 de 2
    • Carefully open the device like a book and lay the two halves beside each other.
  9. Toshiba Thrive Front Camera Replacement, Front Camera: paso 9, imagen 1 de 2 Toshiba Thrive Front Camera Replacement, Front Camera: paso 9, imagen 2 de 2
    • Separate the two halves of your Thrive
    • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
  10. Toshiba Thrive Front Camera Replacement: paso 10, imagen 1 de 1
    • With a spudger, disconnect the cable connecting the camera to the motherboard.
  11. Toshiba Thrive Front Camera Replacement: paso 11, imagen 1 de 2 Toshiba Thrive Front Camera Replacement: paso 11, imagen 2 de 2
    • Lift up the LCD from the screen and place it on the side
  12. Toshiba Thrive Front Camera Replacement: paso 12, imagen 1 de 2 Toshiba Thrive Front Camera Replacement: paso 12, imagen 2 de 2
    • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
    • Lift up the camera from the screen.
Conclusión
Kason
Miembro Desde 09/22/14
1,120 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 10-1, Brown Fall 2014 Miembro de USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 378
