Introducción
This guide will show you the steps required to remove your charging port.
Qué necesitas
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
All of these screws are identical so don't worry about getting them mixed up.
Remove the two screws holding the charging port in place. The screws are 3mm in length and require a PH0 screwdriver.
Using a pair of tweezers, lift up the charging port's protective covering
7 personas más completaron esta guía.
Un comentario
I added "better pictures" flag because i was having trouble following the last step cause i couldnt see anything.
