Saltar al contenido principal
Toshiba Thrive 4G Battery Replacement
Qué necesitas
  1. Toshiba Thrive 4G Battery Replacement, Removing Outer Shell: paso 1, imagen 1 de 1
    • To remove the outer casing, wedge the pry tool in between the front and back panel, and pull them apart.
  2. Toshiba Thrive 4G Battery Replacement, Unlock the Battery: paso 2, imagen 1 de 1
    • Locate the lock switch, at the top left corner of the device, and adjust to the unlocked position. (from left to right)
  3. Toshiba Thrive 4G Battery Replacement, Take Battery Out: paso 3, imagen 1 de 2 Toshiba Thrive 4G Battery Replacement, Take Battery Out: paso 3, imagen 2 de 2
    • Use your fingers to push the release switch, which is located at the top right corner of the device to the right.
    • While pushing the release switch to the right, use your other hand to pull the battery away from the inner casing.
  4. Toshiba Thrive 4G Battery Replacement, Replace Battery: paso 4, imagen 1 de 1
    • To replace the battery, take your replacement piece and flip it upside down, revealing the warnings and specifications of that specific battery.
    • Locate the crevice at the bottom of the battery, which has black openings in it.
    • Line up the black openings with the golden prongs located on the inner casing, and slide the battery into place.
    • Move the lock/unlock switch to the locked position
Conclusión
Courtney Campbell
Miembro Desde 10/22/14
301 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Shastany Fall 2014 Miembro de UMass Dartmouth, Team 1-1, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 226
