Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If your Toshiba Tecra no longer turns on the the battery doesn't last long, this guide gives you the steps to change the battery.
Herramientas
Partes
No se especificaron partes.
  1. Unlock the battery by sliding both tabs at the same time.
    • Unlock the battery by sliding both tabs at the same time.
  2. After, you unlock both sides of the battery, gently slide the battery off by pulling towards yourself. After, you unlock both sides of the battery, gently slide the battery off by pulling towards yourself.
    • After, you unlock both sides of the battery, gently slide the battery off by pulling towards yourself.
Conclusión
Jessica Jaramillo
Miembro Desde 26/09/18
165 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 186
