Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide demonstrates how to properly remove and replace a Toshiba Tecra 8200 RAM in order to preserve the function of the device.
Partes
No se especificaron partes.
  1. Turn off the device and unplug the power cord.
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Slide the battery to the right side until you hear a click. Carefully remove the battery from its compartment. Carefully remove the battery from its compartment.
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Position device so the screen is face down.
    • Position device so the screen is face down.
    • Locate RAM Panel.
  4. Remove two Phillips #00 screws labeled F4. Remove panel.
    • Remove two Phillips #00 screws labeled F4.
    • Remove panel.
  5. Pinch clips on each side of RAM chips to release. Gently remove RAM chips at a 45 degree angle. Use a plastic opening tool if RAM chips do not pop open.
    • Pinch clips on each side of RAM chips to release.
    • Gently remove RAM chips at a 45 degree angle. Use a plastic opening tool if RAM chips do not pop open.
Conclusión
Sally
Miembro Desde 17/02/15
306 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-3, Buehl Winter 2015 Miembro de Ohio State, Team 1-3, Buehl Winter 2015
OSU-BUEHL-W15S1G3
3 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 213
