Saltar al contenido principal
Toshiba Tecra 8100 Keyboard Replacement
Qué necesitas
  1. Toshiba Tecra 8100 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Open the laptop.
  2. Toshiba Tecra 8100 Keyboard Replacement: paso 2, imagen 1 de 1
    • Locate the long, thin plastic panel above the keyboard. This panel is positioned between the top of the keyboard and the screen of the laptop.
  3. Toshiba Tecra 8100 Keyboard Replacement: paso 3, imagen 1 de 1
    • Use the flathead screwdriver to gently pry the panel away from the laptop.
  4. Toshiba Tecra 8100 Keyboard Replacement: paso 4, imagen 1 de 1
    • Removing the panel will reveal a plug that connects the keyboard to the motherboard. Disconnect this plug.
  5. Toshiba Tecra 8100 Keyboard Replacement: paso 5, imagen 1 de 1
    • Once the keyboard is unplugged, gently pull it off. It should easily remove from the laptop. Replace this with the new keyboard. Plug the new keyboard in and replace the plastic panel.
Conclusión
Una persona más ha completado esta guía.
[deleted]
Miembro Desde 09/30/15
122 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 404
