Saltar al contenido principal
Toshiba TDP-XP2 Fuse Replacement
Qué necesitas
  1. Toshiba TDP-XP2 Fuse Replacement, Fuse: paso 1, imagen 1 de 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: paso 1, imagen 2 de 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: paso 1, imagen 3 de 3
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fuse Replacement: paso 2, imagen 1 de 2 Toshiba TDP-XP2 Fuse Replacement: paso 2, imagen 2 de 2
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fuse Replacement: paso 3, imagen 1 de 3 Toshiba TDP-XP2 Fuse Replacement: paso 3, imagen 2 de 3 Toshiba TDP-XP2 Fuse Replacement: paso 3, imagen 3 de 3
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fuse Replacement: paso 4, imagen 1 de 1
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fuse Replacement: paso 5, imagen 1 de 3 Toshiba TDP-XP2 Fuse Replacement: paso 5, imagen 2 de 3 Toshiba TDP-XP2 Fuse Replacement: paso 5, imagen 3 de 3
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fuse Replacement: paso 6, imagen 1 de 2 Toshiba TDP-XP2 Fuse Replacement: paso 6, imagen 2 de 2
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fuse Replacement: paso 7, imagen 1 de 3 Toshiba TDP-XP2 Fuse Replacement: paso 7, imagen 2 de 3 Toshiba TDP-XP2 Fuse Replacement: paso 7, imagen 3 de 3
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fuse Replacement: paso 8, imagen 1 de 1
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fuse Replacement: paso 9, imagen 1 de 1
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fuse Replacement: paso 10, imagen 1 de 2 Toshiba TDP-XP2 Fuse Replacement: paso 10, imagen 2 de 2
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fuse Replacement: paso 11, imagen 1 de 2 Toshiba TDP-XP2 Fuse Replacement: paso 11, imagen 2 de 2
    • Locate the fuse near where the power adapter was.
    • De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
Conclusión
Bryan Underwood
Miembro Desde 04/02/18
697 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 346
