Saltar al contenido principal
Toshiba Satellite p875 s7200 RAM Stick Replacement
Qué necesitas
  1. Toshiba Satellite p875 s7200 RAM Stick Replacement, RAM Stick: paso 1, imagen 1 de 1
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 RAM Stick Replacement: paso 2, imagen 1 de 1
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 RAM Stick Replacement: paso 3, imagen 1 de 1
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Toshiba Satellite p875 s7200 RAM Stick Replacement: paso 4, imagen 1 de 1
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
Conclusión
Danny Amado
Miembro Desde 10/29/18
823 Reputación
5 Guías creadas
Equipo
Baylor, Team S1-G3, Williams Fall 2018 Miembro de Baylor, Team S1-G3, Williams Fall 2018
BU-WILLIAMS-F18S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 346
