Introducción
If you need to replace the disk drive, follow this guide. The disk drive can be accessed from the bottom of the computer. To replace this part, you will need a Phillips 0 screw driver and a plastic opening tool.
Qué necesitas
Remove the battery by sliding the tabs to the left.
Use the spudger to lift the battery out.
Casi Terminas!
Conclusión
