Introducción
After powering the computer up, if it appears that your profile has been deleted or you get messages about the system detecting a ‘critical error’, then there may be a problem with the hard drive. Following the instructions in this guide will allow you to remedy this problem by replacing the hard drive.
Qué necesitas
Unplug the laptop and turn it off.
Flip the laptop upside down.
Locate the battery on the underside of the laptop.
Remove the one 5.0mm Philips #0 screw that holds down the panel covering the hard drive.
