Saltar al contenido principal
Toshiba Satellite U925T-S2120 RAM Replacement
Qué necesitas
  1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: paso 1, imagen 1 de 2 Toshiba Satellite U925T-S2120 RAM Replacement, RAM: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the 9 rubber gripper pads on the back panel of the laptop using tweezers.
  2. Toshiba Satellite U925T-S2120 RAM Replacement: paso 2, imagen 1 de 3 Toshiba Satellite U925T-S2120 RAM Replacement: paso 2, imagen 2 de 3 Toshiba Satellite U925T-S2120 RAM Replacement: paso 2, imagen 3 de 3
    • Unscrew nine 5.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
    • Unscrew two 6.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
  3. Toshiba Satellite U925T-S2120 RAM Replacement: paso 3, imagen 1 de 2 Toshiba Satellite U925T-S2120 RAM Replacement: paso 3, imagen 2 de 2
    • Take off the back panel open by sticking the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 RAM Replacement: paso 4, imagen 1 de 2 Toshiba Satellite U925T-S2120 RAM Replacement: paso 4, imagen 2 de 2
    • Gently pinch the RAM with your thumb and pointer finger.
    • Pull the RAM out of the logic board with gentle force.
    • Try to keep the RAM parallel as you pull it out, so that the RAM does not chip.
Conclusión
2 personas más completaron esta guía.
Equipo
Baylor, Team S5-G5, Williams Spring 2017 Miembro de Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
Miembros de 3
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 592
