Saltar al contenido principal
Toshiba Satellite U925T-S2120 Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
  2. Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 2, imagen 1 de 3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 2, imagen 2 de 3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Unscrew nine 5.8 mm screws using a PH1 screwdriver and turning clockwise.
    • Use the same screwdriver to remove the two 6.8 mm screws.
  3. Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 3, imagen 1 de 2 Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the back panel open by inserting the plastic opening tool into the seam of the laptop and pushing downwards. Repeat the motion around the perimeter of the device.
  4. Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Gently pop out the tab connected to the orange plastic strip.
  5. Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Hold back the orange plastic strip with one hand
    • Use a PH1 screwdriver to unscrew the two 3.4 mm screws by turning clockwise.
  6. Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Lift the silver flap away from the hard drive.
    • Gently pinch and lift out the hard drive with your thumb and pointer finger.
  7. Toshiba Satellite U925T-S2120 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Completely remove the hard drive from the device.
Conclusión
2 personas más completaron esta guía.
Terry
Miembro Desde 03/29/17
137 Reputación
1 Guía escrita
Equipo
Baylor, Team S5-G5, Williams Spring 2017 Miembro de Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 1,781
