Saltar al contenido principal
Toshiba Satellite U840W Processor Fan Replacement.
Qué necesitas
  1. Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: paso 1, imagen 1 de 2 Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: paso 1, imagen 2 de 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Processor Fan Replacement.: paso 2, imagen 1 de 3 Toshiba Satellite U840W Processor Fan Replacement.: paso 2, imagen 2 de 3 Toshiba Satellite U840W Processor Fan Replacement.: paso 2, imagen 3 de 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Processor Fan Replacement.: paso 3, imagen 1 de 3 Toshiba Satellite U840W Processor Fan Replacement.: paso 3, imagen 2 de 3 Toshiba Satellite U840W Processor Fan Replacement.: paso 3, imagen 3 de 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Processor Fan Replacement.: paso 4, imagen 1 de 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: paso 6, imagen 1 de 2 Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: paso 6, imagen 2 de 2
    • Remove the three 3mm screws using a Phillips #00 screwdriver.
  6. Toshiba Satellite U840W Processor Fan Replacement.: paso 7, imagen 1 de 2 Toshiba Satellite U840W Processor Fan Replacement.: paso 7, imagen 2 de 2
    • A plastic prying tool can be used to help you remove the fan.
    • Plastic wire guides hold the wire in place. Manipulate the wire out from these guides.
  7. Toshiba Satellite U840W Processor Fan Replacement.: paso 8, imagen 1 de 2 Toshiba Satellite U840W Processor Fan Replacement.: paso 8, imagen 2 de 2
    • Remove the connector from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Tony Aprile
Miembro Desde 02/04/19
118 Reputación
1 Guía escrita
Equipo
Gateway, Team S1-G1, Saknee Spring 2019 Miembro de Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 317
