Saltar al contenido principal
Toshiba Satellite U405D-S2902 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: paso 2, imagen 2 de 2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: paso 3, imagen 1 de 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: paso 4, imagen 1 de 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: paso 4, imagen 2 de 2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-8, Maness Winter 2013 Miembro de Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 616
