Saltar al contenido principal
Toshiba Satellite U405D-S2902 Display Replacement
Qué necesitas
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: paso 2, imagen 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: paso 2, imagen 2 de 2
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: paso 3, imagen 1 de 3 Toshiba Satellite U405D-S2902 Display Replacement: paso 3, imagen 2 de 3 Toshiba Satellite U405D-S2902 Display Replacement: paso 3, imagen 3 de 3
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: paso 4, imagen 1 de 3 Toshiba Satellite U405D-S2902 Display Replacement: paso 4, imagen 2 de 3 Toshiba Satellite U405D-S2902 Display Replacement: paso 4, imagen 3 de 3
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: paso 5, imagen 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: paso 5, imagen 2 de 2
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: paso 6, imagen 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: paso 6, imagen 2 de 2
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: paso 7, imagen 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: paso 7, imagen 2 de 2
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-8, Maness Winter 2013 Miembro de Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 694
