Saltar al contenido principal
Toshiba Satellite S75D-A7346 Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The Battery: paso 1, imagen 1 de 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The Battery: paso 1, imagen 2 de 2
    • First we have to take out the battery
    • Pull the switch on the left to the left
    • then hold the switch on the right to the right direction
    • then pull up the bttery from the point inbetween the 2 switches
  2. Toshiba Satellite S75D-A7346 Hard Drive Replacement, UnScrewing The BackPlate: paso 2, imagen 1 de 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, UnScrewing The BackPlate: paso 2, imagen 2 de 2
    • Unscrew the screw located next to the information sticker
    • Then get a screw driver or prier to gently pry the covering plate
  3. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The HDD: paso 3, imagen 1 de 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The HDD: paso 3, imagen 2 de 2
    • Unscrew the black screws and then pull the black tab to the right
    • Then lift it out and place it somewhere
  4. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking The HDD Of the Mount: paso 4, imagen 1 de 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking The HDD Of the Mount: paso 4, imagen 2 de 2
    • Unscrew the silver screws and move the hard drive somewhere else
  5. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Adding The New HDD/SSD To The Mount: paso 5, imagen 1 de 1
    • Screw the silver screws into the screw slots furthest away from the connectors
    • Note: This computer is only compatible with 2.5 inch SATA 3Gbps
  6. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Connecting The HDD/SSD: paso 6, imagen 1 de 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Connecting The HDD/SSD: paso 6, imagen 2 de 2
    • Put the Hard Drive in slot (make sure the connectors are on the same side of the connectors
    • Push the Hard Driver into the connector and screw the black screws in
  7. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting On The Backplate: paso 7, imagen 1 de 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting On The Backplate: paso 7, imagen 2 de 2
    • Put on the backplate and put pressure arround the edges of the blackplate so it stays flat with the case
    • Then screw in the screw next to the information sticker
  8. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: paso 8, imagen 1 de 3 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: paso 8, imagen 2 de 3 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: paso 8, imagen 3 de 3
    • Place the battery in the slot
    • Then hold the right switch to the right and push the battery in, then release the switch.
    • move the left switch to the right
  9. Toshiba Satellite S75D-A7346 Hard Drive Replacement, You Finished: paso 9, imagen 1 de 1
    • You have know finished the replacement
Conclusión
Una persona más ha completado esta guía.
Emil Lambert
Miembro Desde 12/16/16
228 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 452
