Saltar al contenido principal
Introducción
If your laptop no longer runs as well as it did, and has become slow, unresponsive, or does not power on. You're processor may be at fault and replacing it could be an option. However before this is done, be sure to check your laptop for any viruses, or any other issues that it may have.
  1. Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Remove the four 5mm Phillips #0 screws from the battery. Unplug the battery from the motherboard. Remove the battery from the laptop.
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Remove the two 5mm Phillips #0 screws from the fan.
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Disconnect the fan from the motherboard.
    • Disconnect the fan from the motherboard.
  6. Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Carefully lift up the processor.
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
Conclusión
Una persona más ha completado esta guía.
William Mazanec
Miembro Desde 29/01/18
1,284 Reputación
8 Guías creadas
Equipo
USF Tampa, Team S5-G6, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 333
