Saltar al contenido principal
Toshiba Satellite S55t-A5389 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba Satellite S55t-A5389 Keyboard Replacement: paso 2, imagen 2 de 2
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: paso 3, imagen 1 de 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: paso 3, imagen 2 de 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: paso 3, imagen 3 de 3
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
Conclusión
3 personas más completaron esta guía.
William Mazanec
Miembro Desde 01/29/18
1,350 Reputación
8 Guías creadas
Equipo
USF Tampa, Team S5-G6, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 577
