Saltar al contenido principal
Introducción
This guide will show you how to fix the stuck Toshiba Satellite S55t-A5389 keys and remove broken/missing ones.
  1. Open up the display and locate the faulty key on the keyboard
    • Open up the display and locate the faulty key on the keyboard
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Using the plastic prying tool, slide the edge of the tool underneath the selected key and pry upwards
    • Using the plastic prying tool, slide the edge of the tool underneath the selected key and pry upwards
  4. If there is any debris underneath key, first clean before replacing it.
    • If there is any debris underneath key, first clean before replacing it.
Conclusión
William Mazanec
Miembro Desde 29/01/18
1,236 Reputación
8 Guías creadas
Equipo
USF Tampa, Team S5-G6, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 85
