Saltar al contenido principal
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
Qué necesitas
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 2, imagen 1 de 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 2, imagen 2 de 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 2, imagen 3 de 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: paso 3, imagen 1 de 2 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 4, imagen 1 de 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 5, imagen 1 de 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: paso 6, imagen 1 de 1
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 7, imagen 1 de 1
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: paso 8, imagen 1 de 1
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 2-1, Blackwell Fall 2016 Miembro de USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Miembros
7 Guías creadas
Un comentario
George, do you know where the graphics chip is at on that motherboard?
Any Where - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,201
